97-02 rear tillights
Old Sep 26, 2007 | 01:40 PM
Ls1Bait's Avatar
Default 97-02 rear tillights
How hard is it to put in 97-02 taillights in a 95 camaro? Do they just plug in like m originals do?
Old Sep 26, 2007 | 01:48 PM
1slowZinthe513's Avatar
i think you have to change the wiring harness.. where your plugs with the bulbs on your 95 would have to get switched with the newer ones.. if im right your 95 plugs wont twist on properly to the backside of the newer lamps
Old Sep 26, 2007 | 05:36 PM
FAD2BLK93's Avatar
PLUG-N-PLAY...direct swap
Old Sep 26, 2007 | 11:11 PM
so the plugs from an lt1 car will snap right into the back of the ls1 style.. i was pretty sure there was some modifying to do
Old Sep 26, 2007 | 11:25 PM
nighthawk15's Avatar
If I remember correctly you need the wiring harness to swap them out.
Old Sep 27, 2007 | 03:31 AM
96lt1m6's Avatar
the sockets are different 93-96 and 97-02
you also need the 5th wire spliced into the harness from the brake switch (blue wire)
back to the taillight harness.
http://www.bfranker.badz28.com/fbody/97lights.htm
Old Sep 27, 2007 | 05:56 AM
3pnt4maro's Avatar
not a direct swap
Old Sep 27, 2007 | 03:25 PM
Ls1Bait's Avatar
I was asking because I want to get a set smoked. I found both sets for sale cheap but I will just go with my stock style and have those smoked.
