clutch question?
Old Sep 27, 2007 | 08:11 PM
lt1swap95's Avatar
Default clutch question?
My 97 lt1 camaro off the start has a hard time catching and im thinking my clutch is going out. In order to fix that do I need a whole clutch assembly or just a new flywheel?
Thanks in advance
Old Sep 27, 2007 | 08:14 PM
CRAZZ28's Avatar
you need a new clutch assembly. Also you need to take the flywheel to a machine shop to be resurfaced.
Old Sep 27, 2007 | 09:04 PM
nighthawk15's Avatar
Yep. You'll need a new clutch assembly and get the flywheel resurfaced unless it is somehow damaged beyond where that's possible.
Old Sep 27, 2007 | 10:00 PM
crazyhorses's Avatar
Yeah, make sure you get the flywheel resurfaced. I didn't do it when I had my tranny rebuilt and new clutch installed cuz it "looked" fine; I had to drop the tranny all over again to get to the flywheel.
Old Sep 28, 2007 | 04:16 PM
nychucky's Avatar
Absolutely resurface the flywheel and also,...Make sure to replace the rear main seal while you're in there. THey are cheap insurance for a bad day.
