lifter noise??
Old Sep 28, 2007 | 08:56 PM
alconk's Avatar
Default lifter noise??
Just recentely I changed the cam, timing chain, all valvetrain and lifers and now I'm getting lifter noise. Did I not get my valve lash tight enough?? They are GM 1.6 RR with there springs. The lifters were Sealed Power from Napa. It kinda comes and goes???
Old Sep 28, 2007 | 08:59 PM
the_merv's Avatar
Veteran: Air Force
How does it sound..
I just had a Lifter collapse in my 402..trust me, that makes a very distinct sound..
Old Sep 29, 2007 | 02:58 AM
alconk's Avatar
Well it's kinda slight and maybe it could be the rockers, I was told that sometimes RR will make noise but not for sure??
Old Sep 29, 2007 | 08:54 AM
the_merv's Avatar
Veteran: Air Force
It probably is...
Old Sep 30, 2007 | 02:01 AM
alconk's Avatar
Do you think I should go back and give each rocker another 1/4 turn?
Old Oct 1, 2007 | 12:02 PM
alconk's Avatar
Well I deffinately think it is the lifters making noise but now I not for sure on what to do?? Should I just tighten them up a little more?? I really heard them this morning, tick tick tick tick ect......
Old Oct 1, 2007 | 01:00 PM
dhdenney's Avatar
I had similar issues but I used the method I had always used with no problems before. Basically I just went back over them and put another 1/8 turn on the nuts and seemed to cure it all up. I used the spin the pushrod method and had a 1/4 past 0 on them total. If you've never had roller rockers before, they are very noisy even when setup correctly.
Old Oct 1, 2007 | 01:42 PM
kinglt-1's Avatar
Yea roller rockers almost make you think something is f-up in the valvetrain. thats why you have to run the lt-4 knock module, which I hope you installed.
Old Oct 1, 2007 | 02:05 PM
dhdenney's Avatar
Or tuned it out.
Old Oct 2, 2007 | 07:23 AM
moserman's Avatar
my car has had SA rocker arms and NSA rocker arms, they all sound like 16 seperate sewing machines under my valve covers but you just have to get used to it.
Old Oct 2, 2007 | 08:36 AM
dhdenney's Avatar
I read some crap somewhere that NSA were supposed to be quieter but I am not sure how that is!
Old Oct 2, 2007 | 08:47 AM
moserman's Avatar
not really, the only difference is just using a guide plate for the pushrods vs having the rocker arms align themself. look for the lightest rocker arm, less mass=less sound. im using harland sharp rocker arms, they still make noise but i can not find anything lighter.
Old Oct 2, 2007 | 10:18 AM
dhdenney's Avatar
Right, I understand. With the NSA setup, you've added friction with the pushrods touching the guideplates. Granted that probably doesn't make any noise, but there's no way that setup can be quieter.
Old Oct 2, 2007 | 11:31 AM
alconk's Avatar
Well I think I'll just go back over them and just turn them another 1/8" turn. And no I don't have the LT4 Knock modual. I haven't had any other problems or a check eng. light?
Old Oct 2, 2007 | 11:41 AM
kinglt-1's Avatar
You wont get a check engine light, your knock sensor will pick up the roller rockers and retard timing=less power than before you put them on.
Old Oct 3, 2007 | 11:21 AM
alconk's Avatar
holy crap.... I didn't know that!!!
Old Oct 4, 2007 | 01:32 PM
goodrich969's Avatar
+1...I guess I need a lt4 knock modual.
Old Oct 5, 2007 | 12:22 PM
alconk's Avatar
Is this a simple install in the PCM or will I have to have it retuned again??
Old Oct 13, 2007 | 11:07 PM
darrell hoagland's Avatar
what rockers do you have
Old Oct 13, 2007 | 11:09 PM
Revelation Z28's Avatar
