need help fast!
Old Sep 30, 2007 | 11:56 PM
JTSLP559's Avatar
yea for ten minutes.. i pulled the wires out of it on the driver side. the bottom wire and inside opti was wet.. so i held the dryer to it..didnt have time to do the other side of the opti..
Old Oct 1, 2007 | 12:01 AM
onephatZ28's Avatar
If the inside of the opti was wet that is why the car will not start. get dry and you will be good to go
Old Oct 1, 2007 | 12:15 AM
JTSLP559's Avatar
yea but how i get it dry is what im debating.. it seems lke its gonna take a while an id like to speed that process if possible
Old Oct 1, 2007 | 08:50 PM
JTSLP559's Avatar
problem solved. pulled the number 1 wire out of the dist. it was weeet. took a blow dryer to her an bam!
Old Oct 1, 2007 | 10:08 PM
onephatZ28's Avatar
Kick *** man. Good luck with the sale
Old Oct 1, 2007 | 10:31 PM
JTSLP559's Avatar
thx bro. i went back out right now to start it up.. it struggled alittle before it started.. but it eventually did, so its probly still alittle wet? if so should i let it run for a while? or keep blow drying?
Old Oct 4, 2007 | 10:34 PM
onephatZ28's Avatar
I would just let it run and heat up
