Fuel Pressure Question
Old Sep 29, 2007 | 05:43 PM
1sicss's Avatar
Default Fuel Pressure Question
does anyone know what the factory fuel pressure should be at and what do ya'll have it set at after ya'll have done H/C. Because I have no idea as to what mine should be set at? THANKS!!!!!!!!!
Old Sep 29, 2007 | 06:42 PM
97blackz28's Avatar
don't mess with the fuel pressure, as no matter what you set to after a few cycles your pcm will recognize the difference and adjust to get it back to where it thinks it should be. basically you can not tune by adjusting fp like some other cars.
Old Sep 30, 2007 | 02:57 AM
Formula350's Avatar
Vacuum line pulled off, 43psi.
Old Sep 30, 2007 | 09:07 AM
buffman's Avatar
vacuum line off should be about 44-45 psi MAX
