Vibration At 75 & On Up
Old Oct 3, 2007 | 08:05 PM
BIGBTRIPLETT's Avatar
Default Vibration At 75 & On Up
Just replaced engine in a 96 trans am ws6 lt1 with autocrmatic. We put the car in the air and you can still feel it. We left the trans in the car and I think the driveshaft may have slip out I know these are supposed to be marked before you take them out know what do i do
Thanks
Old Oct 3, 2007 | 08:09 PM
dhdenney's Avatar
Are you using stock steel shaft? Which torque arm are you using?
Old Oct 3, 2007 | 08:10 PM
ThoR294's Avatar
when you remove a driveshaft, you should always mark the Ujoints... they are balanced that way. apparently LT1s all have a high speed drive shaft vibration *shrug*
CRAZZ28's Avatar
Replace the u-joints.
The driveshaft cannot "slip out" unless the motor and trans mounts are not connected or there is something seriously wrong with the rear end.
Old Oct 3, 2007 | 08:15 PM
we are using a alum drive shaft.Can the yoke splines between the trans and the yoke be out of alignment? We had the enging out and the trans loose so thats how i think it slip out of the trans does this matter
Old Oct 3, 2007 | 08:18 PM
CRAZZ28's Avatar
as long as everything is tight now it should not matter. Where did the driveshaft come from? It may be just plain out of balance.
