Oxygen Sensor removal
Old Oct 6, 2007 | 05:46 PM
HoLLo's Avatar
Default Oxygen Sensor removal
Unable to get my damn sensors off. Soaked them in PB, and they are locked down hardcore. Gonna have to torch them probably, but for those who have replaced them? What was your easiest way to change the passenger side?
Old Oct 6, 2007 | 05:54 PM
z28hustle's Avatar
thats really a good question .. i need to replace mine as well and didnt even see one in the passenger side hooker long tube header
Old Oct 6, 2007 | 09:18 PM
Pony_Killer's Avatar
back before I put my headers on I had to change the o2's and my driver side took less then a minute and the passenger side I had to cut it in half so I could put a socket on it and just use some muscle...
Old Oct 6, 2007 | 09:22 PM
Ralls's Avatar
There's not much you can do besides use heat and pb blaster. You want to use a socket or closed end wrench on it so you have as much surface area on the nut as possible. Since they are being replaced, cut the wire so you can put that socket or wrench on it.
Old Oct 6, 2007 | 10:09 PM
infinitebird's Avatar
Cut it and use a socket, as said. Regular wrench won't get enough torque on it sometimes.
Old Oct 6, 2007 | 10:20 PM
Formula350's Avatar
Try and tighten them first to break it loose. Works more times than you'd think. Bolts too.
Old Oct 6, 2007 | 10:45 PM
Camaro_freak's Avatar
I used PB bllaster and ran the engine for a few minutes to heat up the exhaust pipes. Still took some muscle, but it came out.
Old Oct 7, 2007 | 12:44 PM
Hackscamaro's Avatar
when i did mine on the passenger side i soaked it in pb blaster got a wrench on it couldnt get it to budge so i moved the started forward enough to where i could use another small wrench as a cheater and it came right out.
Old Oct 7, 2007 | 01:36 PM
blk97z28's Avatar
I had to use heat on mine, when I had stock manifolds.
Old Oct 8, 2007 | 09:09 PM
REBORN Z28's Avatar
PB, Heat, 7/8 deep socket, six pack of favorite beer, and a little luck.
