???? lt1
Old Oct 11, 2007 | 02:33 PM
dhdenney's Avatar
Originally Posted by BlackScreaminMachine
I beleive holley makes a throttle body with a integrated n2o ports.
It's a dry shot piece, just so you know.
Old Oct 11, 2007 | 03:01 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Yea, I havent been doing LT1 stuff for a while it was just coming out when I stopped, I didnt see if he ran a wet shot or dry.
Old Oct 11, 2007 | 05:30 PM
96capricemgr's Avatar
Originally Posted by SprayedZ
I have a 1995 camaro z-28, I have a cat back, MAF, cold air, shift kit, programmer, and a 75 shot of nitrous. I am getting headers in about a week. Just wondering what else to do.
An aftermarket MAF is a mistake, would go so far as to call it dangerous with nitrous.
On a shift kit Transgo is the ONLY right choice.
If "programmer" is Hypertech then again garbage.
After the headers I would look at gears or a stall, roller rockers and matching springs would be OK but you are far from ready for a cam.
I do not kow where the TR4 sparkplug recommendation came from earlier, if there is such a plug it would be HOTTER than stock, point being watch who you take information from. For every 1 guy who knows what he is doing there are several kids without a clue who mean well but will lead you down a bad path.
Old Oct 11, 2007 | 08:25 PM
dhdenney's Avatar
Oh yeah forgot about those plugs. Use TR6's at that level.
Old Oct 11, 2007 | 09:45 PM
SprayedZ's Avatar
Ok going threw trying to get my pcm programmed, i went to madz28 and they said that for the 94 and the 95s are obdI and my car is obdII. How do get that programmed
Old Oct 11, 2007 | 09:48 PM
SprayedZ's Avatar
I got the plugs from NX that was what was recomminded, i also forgot to say that i have 3.73 gears.
Old Oct 11, 2007 | 10:05 PM
SprayedZ's Avatar
ok Say i do end up getting the 52mm throttle body. Do i need to do anything to my intake? Is the valve springs a must with new roller rockers, bc i was to at my speed shop that they will hold up???
Old Oct 12, 2007 | 06:28 AM
Internet Mechanic
That was my bad, a miss type, i just caught it, I meant TR-6's, which I would assume if I am talking about nitrous safety equipment you would just clarify it for me.....
I never used anything other then a Stock GM MAF, especially when tuning, it can throw off the info the tuner puts in and can damage the car. If you tell them you have one they can work around it.
As for the TB all you need to do is follow the directions if they require the slotting of the TPS sensor to retain the same Voltage at idle, and swap the sensors over.
Springs are required to ensure long life. Some people have put them on with out issue but they are the minority, rather then the majority.
unless the car was converted, its a ODB1 pcm.
Old Oct 12, 2007 | 11:12 AM
SprayedZ's Avatar
Ok thanks this is def. helping me out. So since my car is a 95 it has obdII conectors but a obdI PCM? Is there any way that i can switch my springs out with out taking the heads off? Is is good to take all of the egr bull **** off of the car so i can run race headers?
Old Oct 12, 2007 | 11:49 AM
Internet Mechanic
id go here, speak to Andrew, a really nice guy and a great FAQ section on the pcm/connector thing....
http://www.akmcables.com
The headers should be removed anyways, then you have a lot of room, a air compressor and appropriate fitting should be more then enough. Make sure both valves are closed so the valves wont drop in.
As for emissions, its primairly for weight, the EGR shuts off at WOT, Also it makes it easier to work on the car, so there is an advantage
Old Oct 12, 2007 | 12:42 PM
SprayedZ's Avatar
So what happens if i just take it all off and do the block off plates? Does it hurt anything, and will i have to do anything else so it dont throw codes. What do you think i should do buy the headers with the egr **** or buy the race headers and then do away with the egr stuff?
Old Oct 13, 2007 | 06:52 PM
  #32
SprayedZ's Avatar
So how much HP and torque am i looking at gaining with the headers, throttle body, roller rockers, and a PCM tune?
