Car is breaking up and misfiring...
Old Oct 14, 2007 | 10:07 AM
Matts94Z28's Avatar
Default Car is breaking up and misfiring...
I just put the motor in a week ago and i only have about 250 miles on it. It was driving fine for about 3 days and then one day after class it was misfiring really bad. It feels like it might be running on 7 cylinders or something.
This happens in open and closed loop, through the whole rpm band, and its SLIGHTLY noticable at idle. I cleaned the MAF, put in new plugs gapped at 35, and checked for arcing under the hood. It also smells rich sine this has been going on. The opti is less than a year old and i have an MSD coil that is from 2001.
Can you guys give me any ideas? Im lost here and i need to figure this out so i can continue to break this motor in.
Old Oct 14, 2007 | 10:18 AM
dhdenney's Avatar
Any DTC's?
Old Oct 14, 2007 | 02:54 PM
Matts94Z28's Avatar
Nope not according to free scan
Old Oct 14, 2007 | 03:11 PM
dhdenney's Avatar
Since no codes, I'd check my plug wires really close. Double check wire order as well. Do you think maybe you have a fuel related problem such as regulator?
Matts94Z28's Avatar
Number 6 primary is cooler than the rest after running...
Old Oct 14, 2007 | 03:43 PM
dhdenney's Avatar
Hmm... but you've checked its wire and all that jazz?
Old Oct 14, 2007 | 03:46 PM
Matts94Z28's Avatar
Im about 90% sure its a wire. Im going to go buy some cheap autolite and see what happens. I should know in about an hour or so. I hope its not an issue with the cylinder or something, hell it was running fine last wed!
Old Oct 14, 2007 | 03:49 PM
dhdenney's Avatar
Well just buy one wire and check it out.
Old Oct 14, 2007 | 04:16 PM
Matts94Z28's Avatar
Yeah i picked up one wire just now so we will see...im pretty sure this will fix it.
Old Oct 14, 2007 | 04:30 PM
Matts94Z28's Avatar
fixed!!
Matts94Z28's Avatar
now i have to run around on some autolites until i can buy some more taylors.
Old Oct 14, 2007 | 04:41 PM
dhdenney's Avatar
You probably won't even notice.
Old Oct 14, 2007 | 04:42 PM
Matts94Z28's Avatar
lol i bet you are right, also i probably won't actually get around to ordering the new wires until spring...I'm lazy.
Old Oct 14, 2007 | 04:53 PM
Matts94Z28's Avatar
Here's what she sounds like since the rebuild...
Old Oct 14, 2007 | 06:01 PM
dhdenney's Avatar
Sounds great!
