roller rockers need help
Old Oct 18, 2007 | 04:44 PM
powers84's Avatar
Default roller rockers need help
there are 3 roller rocker nut that wont screw on dont know why. turned motor and everything. help
Old Oct 18, 2007 | 07:12 PM
MUSTANGBRKR02's Avatar
they are stock heads, GMPP RR's and there are three that will not sit down far enough to start the nut on the stud?????
Old Oct 18, 2007 | 09:24 PM
Horsepwraddict's Avatar
If you are talking about poly locks? is the set screw backed out?
Old Oct 18, 2007 | 10:39 PM
yes it is. There are only 1/2 a thread showing on these studs. I stopped by today for a look. Need some idea's he needs the motor back in before i leave Sunday morning.
Old Oct 19, 2007 | 09:20 AM
i know you said you turned the motor over, but do it again, unless its a deformed rocker the only thing that could keep it up off the stud is if you are trying to install it with the pushrod all the way up because the lifter is on a lobe.
Old Oct 19, 2007 | 10:58 AM
powers84's Avatar
im putting in the` stockers for now
