Whats the name?
Old Oct 20, 2007 | 05:57 PM
SSrollin22s's Avatar
Default Whats the name?
Whats the name of the sensor on the bottom of the throttle body? I know you got tha throttle position sensor on the side, but whats tha other one name?
Old Oct 20, 2007 | 05:59 PM
erickeown's Avatar
Air intake temperature, ait
Old Oct 20, 2007 | 06:02 PM
Thanks bro !
Old Oct 20, 2007 | 06:09 PM
nychucky's Avatar
Are you sure that isn't the idle air control valve. The intake temp sensor is located in the elbow
Old Oct 20, 2007 | 06:12 PM
AWWWWW hell which one is it?
Old Oct 20, 2007 | 06:23 PM
Speed Density's Avatar
hashtagBMW
The sensor directly under the throttle body is the Idle Air Control unit, its a sensor and has the coolant peice. (IAC)
The one on the elbow before the throttle body is the Intake Air Temp (IAT).
Tony.
Old Oct 20, 2007 | 06:27 PM
erickeown's Avatar
Tony.
missread it, this is correct
Old Oct 20, 2007 | 09:34 PM
Okay good lookin out yall!!!
Old Oct 20, 2007 | 09:41 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Old Oct 21, 2007 | 01:54 AM
Formula350's Avatar
Your IAC might be like mine, which is a square-4 plug. Not the Flat-5 Plug in the picture above. It'll also be pointing out to the side, not towards the front as the pictured one does.
