Lost to my Nephew. ?
Old Oct 23, 2007 | 01:26 AM
slagger's Avatar
Default Lost to my Nephew. ?
Hi all Well I don't know if I should have won even though Ihave the 2.73 gears but he has a 1999 stock T A w/ jet chip 6 speed none WS6 so we did a 5mph roll he didn't hook up to good but it started out even then he started to pull on me alittle to where hi tail pipes were at my side then he shifted then he got a car lenght ahead and it didn't look like I was catching up but we ran out of room and let off.
I know I have the 2.73 rear gears but I would have hope to keep even aleast
I know when I had my 3.42 gears my car felt alot faster alot but.
he running 2.73 to but 6 speed
right now I feel like going to 3.73 and see what that will help.
thanks for listen guys.
Old Oct 23, 2007 | 01:39 AM
1slowZinthe513's Avatar
you said it!.. you should for sure go with the 3.73 gears
LOOKINGFORWS6WHEELS's Avatar
If you have all that done and he beat you sell it.
My TA is an auto 94 open header 3.73 Built Tranny w/shift kit K&N and some other mild bolt ons but it will keep up with any stock ls1
Old Oct 23, 2007 | 02:06 AM
BIG_T's Avatar
with my bolt ons and 4.11's in my m6 i give i/h/e ls1 guys a good run
Old Oct 23, 2007 | 06:31 AM
DarkKnightTA's Avatar
Are you sure he has 273 gears, I thought all 6spd 4th gens came with 342, even if he did a tranny swap he would still have 323 gears. Atleast the 96 and up a4 had 323 and m6 had 342...correct me if I am wrong.
Old Oct 23, 2007 | 11:30 AM
vetman1's Avatar
what he said.
Old Oct 23, 2007 | 11:38 AM
kinglt-1's Avatar
Lock this thread please!
Old Oct 23, 2007 | 11:44 AM
yes lock it down.
 Michael S. Palmer
Old Oct 23, 2007 | 12:13 PM
slagger's Avatar
I might be wrong he said at 86mph he turning 2000rpm
Ok I found a calc on gears and he has the 3.42 I don't feel to bad now because my car pulled really good when I had the 3.42.. I'm looking for some 3.73 gears
Old Oct 23, 2007 | 12:16 PM
slagger's Avatar
I feel like that, I remember when my motor was stock and I had 3.42 gears it pulled good.
Old Oct 23, 2007 | 12:40 PM
ThoR294's Avatar
um. he has 3.42s
Old Oct 23, 2007 | 12:49 PM
RED94Z28's Avatar
I used to have a 2002 Z28 m6 and i believe they are all 342'S
Old Oct 23, 2007 | 01:10 PM
Ok, 94 and up 6spd cars came stock w/342, the a4's were a little dif. 94-95 had 273 and 96 and up had 323.
Old Oct 23, 2007 | 01:30 PM
Formula350's Avatar
I though A4s (like mine, but it's a 93) could come with 3.23s as well...
Old Oct 23, 2007 | 01:50 PM
CamaroRacing12's Avatar
pretty sure my 95 A4 has 3.23's as well
Old Oct 23, 2007 | 01:55 PM
I am sorry, there were two different carriers, like a 2 or 3. I think it depended on the options of the car.
Old Oct 23, 2007 | 03:26 PM
koolaid_kid's Avatar
Stock was a series 2 carrier with a 2.73 gear.
Optional performance package was a series 3 carrier with a 3.23 gear.
M6s came with a series 3 carrier and a 3.42 gear.
Old Oct 23, 2007 | 04:09 PM
Formula350's Avatar
GU5 is the option code for 3.23 if that helps
Old Oct 23, 2007 | 04:27 PM
Hugger-96-lt1's Avatar
So the mods on your sig are what you were running against that stock TA. I would of thought you beat him. and pretty good.
Old Oct 23, 2007 | 04:33 PM
fbodyracing1's Avatar
i think 93 and 94 had 273 with the 6 speed and 95 and up had 342
