Obd1 Obd2
Old Oct 23, 2007 | 03:19 PM
Yngvar's Avatar
Default Obd1 Obd2
which computer system is more mod friendly? I am look at buying a lt1 I don't know if I should get the 93-95 with OBD1 or 96-97 with the OBD2 I am looking at porting heads and a cam
Old Oct 23, 2007 | 04:13 PM
Formula350's Avatar
Well, "easier to mod" is quite vague. Do you mean the computer, or the motor? The motor is basically the same OBD1 or 2.
If you mean the computer, 93 is alone with having an ECM instead of a PCM. They don't require much for software to tune, but you need to have whatever file you do make up, burned to a new EPROM and then install it (burners run $100~). The 94+ are PCM, and they have EEPROMs that you tune via a laptop, but the software for that I believe is like $300+, and you need a computer, as well as a ALDL cable ($60+). Most people prefer the OBD1 systems, and there are quite a few OBD2 people that convert to OBD1.
Old Oct 23, 2007 | 04:29 PM
infinitebird's Avatar
Obd1 is easier to tune and the software is cheaper. 94-95 software costs the same as 93 (if you use tunercat), but 93 you have to get a chip burner also. obd2 software is more (lt1edit).
The main advantage of obd2 is if you live in an emissions area, it is much easier to pass inspection.
Old Oct 23, 2007 | 05:07 PM
Yngvar's Avatar
I live were their is no emission test and thank you for the help
Old Oct 23, 2007 | 10:22 PM
97HawkLT1's Avatar
It is very easy to convert the computer to OBD1 if you have a 96 or 97 (I just converted mine). So if you find a later model, don't decide on just the computer. OBD1 is cheaper/easier to mod the computer as it isn't as picky as the OBD2.
Old Oct 24, 2007 | 01:41 PM
Stroked96Bowtie's Avatar
I also was told that once you start really mod'ing the car, cam, heads, etc. The OBD1 will typically allow the car to make more power than the same setup on an OBDII. Something about OBDII not liking heavy mods.
Curious if others have heard this also?
Ive been looking for a deal on an OBDI to prove it right or wrong.
