High HP guys, will this PCV setup work?
Old Oct 24, 2007 | 08:45 AM
FASTFATBOY's Avatar
Default High HP guys, will this PCV setup work?
http://
Both valvecovers are baffled, the #12 will be welded in the valvecover.
Under full throttle blasts the breathers I have in the valvecovers drip on the headers. I figure under cruise the PCV system will work, pulling air from the Moroso vent tank filter, under wide open throttle it will push into the Moroso tank instead of all over my headers.
Thoughts?
Thanks
David
Old Oct 24, 2007 | 10:49 AM
Tony Shepherd's Avatar
Well......at WOT you really do not have enough vaccum to do any good on that kind of setup. May help a little but not much in my opinion.
Will work fine under part throttle.
