Is it ok?
Old Oct 28, 2007 | 11:32 AM
transamws6_97's Avatar
Default Is it ok?
to change your oil on an incline? I cant use my garage and the only place I can do it is my driveway which has a small incline
Old Oct 28, 2007 | 12:50 PM
jester1614's Avatar
it should be fine.. i would do it positioned so the drain plug was toward the bottom of the incline.
then put 5 qts in and check it on a level surface
Old Oct 28, 2007 | 03:45 PM
Ralls's Avatar
Jack it up so it's level.
Old Oct 28, 2007 | 03:49 PM
TAEnvy's Avatar
I did mine once with the front wheels up on ramps, drained out right under 5 quarts so I think it worked, plus every time I drive the cars its a LONG trip, so I dont get alot of condesation in the oil, making it look like more is in there than really.
