Oil pressure sensor
Old Oct 29, 2007 | 02:46 PM
KriegerEhre's Avatar
Default Oil pressure sensor
My Oil pressure gauge has been stuck above 80 since I dropped my kmember then bolted it back, I looked at the wires and they where pretty cut up so i went and bought a new sending unit to tie into the harness. . .I pluged it back in turned the car over and BAM still stuck on 80 - do you think A, I should go back and try and rewire the wires together maybe using something that'll merge them together better or B. do you think the sensor itself is gone bad and should be replaced next oil change?
Thanks for your info!
Old Oct 29, 2007 | 06:12 PM
Speed Density's Avatar
hashtagBMW
Sounds like your sensor is gone, thats exactly how mine was acting when it was trashed.
Tony.
Old Oct 29, 2007 | 06:58 PM
nychucky's Avatar
If your sensor is new then try to rewire the sensor back into the harness. I think it is only one wire into the pigtail. I broke mine replacing #7 spark plug,....whoops
