when is a head too big?
Old Nov 5, 2007 | 06:53 PM
fergymoto's Avatar
LOL who said they were junk?
Old Nov 5, 2007 | 06:57 PM
BMC_Punisher's Avatar
sorry fergy i thought you were saying aluminums were junk i didnt say stock castings were junk. If thats what you mean. There is nothing wrong with cast heads ported. LOL you guys a f'n crazy.
Old Nov 5, 2007 | 07:23 PM
fergymoto's Avatar
I didn't say anything was junk. I am a big fan of aluminum heads. I was just saying most aftermarket aluminum castings are considerably stronger than OEM ones and anyone that got the money should spring for them, really it's a better investment if you got the cash.
Old Nov 5, 2007 | 08:22 PM
ABA383's Avatar
I was being a wise *** in my post, but the problem with your thinking is that I've yet to see an aftermarket head give better results without a bunch of port work $$$$ done to them...For the majority of us a properly ported set of stockers will work fantastic...I still think that the LPEs are one of the best out there, and I've had mine for almost 13 years...If I had the money I'd rather spend it elsewhere where it would do more good...Just my .02...
--Alan
Old Nov 6, 2007 | 12:21 AM
Boodyrider's Avatar
Hush up Alan, you hafta spend your money on a trans because those lame ported stockers of yours killed it!
AFRs may well be too much for a stock cube motor. Personally, I'd buy/build a killer short block first, either 355 or 383, and have a long lived core to put good stuff on later.
Old Nov 6, 2007 | 12:58 AM
Thanks for the smart *** coment aba lol. I agree with you completely stock ported heads can kick some serious ***. But he says he has the cash to spend then he should do it cuz once you go fast your only going to continue to go faster. So why not have a cylinder head that is ready for it. I would agree a 355 or 383 would be a real good investment for a set of bigger afr's. But even the basic afr head is a cnc'd port and you can upgrade the the fully cnc'd ported head with a bowl finish. I would like to see any machinist try to port to the accuracy of a cnc machine it cant be done.
Old Nov 6, 2007 | 01:08 AM
speed_demon24's Avatar
Um LPE, AI, TEA, ect are all cnc'd.
Old Nov 6, 2007 | 01:15 AM
I never said they werent. What im getting after is to just get a cylinder head right out of the box ready to rock. You wont need to do any crazy port work to make them work they are ready to be bolted on and ran. I dont if what your getting after is that LPE flow better than afr? So whats the flow numbers on an LPE factory head right out of the box.
Old Nov 6, 2007 | 10:37 AM
fergymoto's Avatar
I wouldn't doubt the LPE worked heads outflowing the out of the box AFRs. They are a very good head. I would like to see what they could do with some Brodix, AFR, or Dart heads.
Old Nov 6, 2007 | 11:24 AM
kinglt-1's Avatar
--Alan
Yea LPE does a nice job! Al the headporter at LPE reworked my heads. He told me the cnc program for the stock lt-1 head is over 15yrs old. It is amazing LPE had technology other shops are just now catching up to. AL hand ported my heads because he said that he could open them up more by hand than cnc. Also since the cnc program is outdated there are improvements that can be made. It does not warrant them to spend the money to keep on the cnc r&d for the LT-1. Especially with all of the LS-x stuff that keeps them busy. Although, the last time I spoke to Tom Cress he said they worked on 7 LT-1's the weeek prior!
Old Nov 6, 2007 | 11:58 AM
ABA383's Avatar
Yeah, LPE seems to be gaining in popularity with the LT1 folks again...I keep in touch with them on a regular basis to let them know how their almost 13 year old motor is doing...My LPE heads were re-ported by Eric Bradby in 2005 to find a bit more air, but he said that the LPE heads are some of the best he'd seen and were very respectable...We figured that the LPE CNC program was older, but it still does very well especially if you have the LPE porter hand finish them...I still think they are one of the best heads going for the LT1...I'm proof that they flow well enough to help me go 121 in a heavy car...John (RIP) told me once that while flow is very important, the velocity of the flow should not be overlooked. I'm sold on the whole thing...
--Alan
Old Nov 6, 2007 | 12:00 PM
  #32
ABA383's Avatar
I almost missed your post Paul...Damn heads cost me a trans...
--Alan
Old Nov 6, 2007 | 01:41 PM
  #33
I dont know fergy. I couldnt find a flow sheet on the LPE site. He did have some generic specs but they werent much to get enough info from. I did check the AI site and they had some sheets but theyre 200cc head would be out flowed by AFR's 195's easily at less lift to. I do agree with aba though its amazing your 13 year old LPE's are still going strong and what you have run 11.2's is very respectable numbers. The LPE's sound like a good head
Old Nov 6, 2007 | 02:08 PM
  #34
95Lwind05's Avatar
I agree as well last year i put N20 to her, and with almost 400HP to the wheels, its still not enough
thanks everyone for all the feedback...keep it coming!
Old Nov 6, 2007 | 02:52 PM
  #35
Kaptain Kirk's Avatar
Would you ever complain about getting good head?
Old Nov 6, 2007 | 05:55 PM
  #36
96capricemgr's Avatar
Most AFR fans will tell you their flow bench is "happy" to say the least particularly on their under 210cc heads. Also check bore sizing some aftermarket heads are published using a 4.155 bore(.030" over 400 smallblock) where shops like AI publish 4.030" bore numbers. One LT1 specialty shop even uses a 4.060" bore though that is not that common on street LT1s, good for numbers though and most guys wont notice.
Reader has to try and make sure he compares apples to apples and even then you need to understand there are many ways to fluff the numbers and many shops are willing to do just that. As has been stated too flow isn't everything, the only reason we talk about it is is is a cheap and easy test compared to the only real test which is the track.
Old Nov 6, 2007 | 06:31 PM
  #37
I do agree caprice. I do realize the bore size and yes afr's are tested at a .060 over bore i do understand to that the specs we read on site or out of magazines is the template head for the rest of that line of heads. The flow numbers will not be identical to that which i have read but dam close. On top of that the afr's base head has 2.050 intakes and 1.600 exhaust valves with an upgraded head that has 2.080 in and 1.600 ex. Compared to a stock casting to which has 2.00 intakes and 1.55's ex on a lt4 head. The only true way to see if the head makes good power is to really build it and test it. But when we talk about cylinder heads and choices how will you select a cylinder head the only way you will no what head you want or will work is flow numbers. I firmly believe you can make any combo work as long as you choose wisely on your camshaft and cylinder head combo.
Old Nov 6, 2007 | 07:09 PM
  #38
B4C_LT1's Avatar
guys this is easy...a head is too big when your neck hurts
Old Nov 6, 2007 | 08:57 PM
  #39
FASTFATBOY's Avatar
A head is too big when you cant find a hat or helmet to fit it!
An AFR 195 is not too big for a stock bottom end car as long as it is cammed correctly.And has all the supporting mods.
I have a 250CC head on a 383 that peaks at 6700 rpm. And makes pretty good power.
David
Old Nov 7, 2007 | 02:49 PM
  #40
Vicious95Z28's Avatar
Well, **** I'm throwing my 13 year old junk LPE/E.B. Porting stock castings in the trash...thank god for this thread.....I was starting to go too fast anyway...
--Alan
Alan, make sure that you throw them in my direction. PM me for a good shipping address.
