Best air/fuel ratio
I have a question for the tuners here. I have a 95 a4 z28 with mild ported stock heads and cam. The car is currently running 11.90s at 113 with the stock fuel system (pump and injectors). Injectors are near max duty cycle so I just purchased a new LM-1 wide band set up to verify what was going on in there. My car reads 12.5 or so wide open until the last 400 rpms right before it shifts it will spike up to 13.0-13.2, i know this is lean but how bad is that? I have 7 1/4 mile passes in this current tune and i am hoping i wasnt to hard on my pistons.
I'm no tuner, but I've heard that around 13.0 A/f is good for performance.
Keep it at about 14.7 at idle and cruise... Better gas milage and any richer is just a waste, leaner is dumb idea of course.
When WOT 13/1 is about perfect. A little rich is never too a bad thing (though way rich is). Lean it anymore than 13/1 while WOT and your asking for trouble.
With a turbo car you want to aim for 11-11.5/1 while WOT. If I see a 12 on my gauge i'll get out of it. Holes in pistons aren't cool!
Jason
I'm no tuner and definitely am just listening-in but had to ask : You guys mention 14.7 AFR fior cruising,... Isn't that what the car will automatically try to find in closed loop under casual driving conditions? I was under the impression you can only tune our cars AF mixture for the open loop mode -- Which, if thats the case then it would only be when your putting the pedal to the floor (unless you're keeping it in open loop all the time somehow). I'm only referring to the stock GM computer as well.
yes the car in closed loop will try and go to 14.7 unless the BLMS are off.
