4inch exhaust
Old Nov 2, 2007 | 09:25 PM
bricez28's Avatar
Default 4inch exhaust
where the hell do you get the mufflex 4 inch???
Old Nov 2, 2007 | 10:27 PM
TwoFast4Lv's Avatar
Have you tried HERE?
Old Nov 2, 2007 | 10:51 PM
Paul Bell's Avatar
That's MISTER MODERATOR
You could drive down to south Jersey and let them do the install. It’s really difficult and I couldn’t imagine it not being fully welded like they do it.
HOWEVER, while letting them do it, make sure the muffler is up as far as it can go, not hanging way down like they did mine AND make sure the pipe doesn’t hit everything along the way like mine AND ask them why they have to jam a rubber wedge between the pipe and the hump like they did mine.
That’s right guys, I think they did a poor job and in the end I wasn’t a happy camper. In hindsight, I wish I spent more money and got the Kooks true dual stainless system. For our engines, dual 2.5's is plenty. BRICEZ28, give Kooks a call. Hell, they’re way closer to you in Bayshore. I’ll be planning to have Kooks do mine next year.
Old Nov 2, 2007 | 10:55 PM
TwoFast4Lv's Avatar
I am just trying to find the 4in over the axle because duel 2.5s is NOT enough for my car
Old Nov 2, 2007 | 11:42 PM
Paul Bell's Avatar
I suppose that if you jave a krazy enough engine, dual 2.5's may not be enough. I know Kooks also has a true dual 3 inch all the way. They won't sell it as a kit, it's strictly a item they install. Its custom bent to fit each car.
Mufflex will sell the entire kit and I'm sure just the parts alone.
Old Nov 2, 2007 | 11:45 PM
TwoFast4Lv's Avatar
Thanks!
You probably think I am crazy but My dyno curve rolls over just past what your Monte does, at the rear wheels. Is that the one you have 2.5s on?
Old Nov 3, 2007 | 12:07 AM
Paul Bell's Avatar
Nope. Never said what the Monte has. It's got a full 3 inch system. It dyno'ed at 596 HP at 5,250 RPM and 592 ft-lbs at 2,500 RPM.
It was built and run in about '93. If I did this motor over today, I'd get easily over 700 HP with better heads and cam.
