10.935 @ 124.09
Old Nov 3, 2007 | 04:15 PM
jakesz28's Avatar
Default 10.935 @ 124.09
Well I finally made it to the tens. The tranny is junk, slips at every shift. But I think Ellis was right about the stall. The last time I went it was on the rev limiter every shift. The converter is too loose. I had to lower the mph shift points to stay off the limiter but the tranny takes way too long getting into the next gear.
60ft 1.540
330 4.546
1/8 7.014
mph 100.17
1000 9.128
1/4 10.935
mph 124.09
Well its time to take it apart and get it ready for next year.
Old Nov 3, 2007 | 04:18 PM
9formula4's Avatar
how many cars ended up attending mike? I sent a guy over.
Old Nov 3, 2007 | 04:20 PM
jakesz28's Avatar
There was a good turn out and some nasty f-bodys showed up.
Old Nov 3, 2007 | 04:24 PM
SmokedOutZ28's Avatar
Congrats on cracking the 10s Whats your setup?
Old Nov 3, 2007 | 04:51 PM
jakesz28's Avatar
Everyone will call me a lier. Stock short block and heads. Cam only, with nitrous, exhaust, 3600 stall, 4.10's, torque arm, LCA, PHB, 28x10.5 slicks.
Old Nov 3, 2007 | 04:52 PM
jakesz28's Avatar
Old Nov 3, 2007 | 05:02 PM
Ls1Bait's Avatar
Dam man Nice times... You have my same setup without the nitrous.. Even your N/A motor times are the same as mine
I gotta get my car on the bottle
Old Nov 3, 2007 | 05:08 PM
Jditlfm's Avatar
What are you running for a set up? still stock bottom end?
Old Nov 3, 2007 | 05:27 PM
Gun5's Avatar
damn what shot?
Old Nov 3, 2007 | 05:42 PM
jakesz28's Avatar
They say not to go over 200 shot on the stock intake without going direct port but I did.
Old Nov 3, 2007 | 07:29 PM
Vicious95Z28's Avatar
Schweet G! I'm glad to hear she did so well
Old Nov 3, 2007 | 08:48 PM
94 F-body's Avatar
Congrats on the 10's
Old Nov 3, 2007 | 08:50 PM
TwoFast4Lv's Avatar
Congrats man! Time for the next stage
Old Nov 3, 2007 | 11:11 PM
TAEnvy's Avatar
IS that a nitrous verter, if not what does it stall at?
Old Nov 4, 2007 | 03:59 AM
jakesz28's Avatar
I would say it is flashing to 4500 or so. Its a 3600 vig not really set up for this combo.
All summer the car would 60ft mid 1.50's on a 150 shot. When I flashed the converter on a 200 shot the car would leave hard pulling 1.48's. But the last two times out the car had a problem leaving the line. The car would start to pull the front end then fall on its face. I pulled the plugs and changed them yesterday added a little more fuel then added a little more timing but I did not get a good 60 foot.
When pulling 1.48 I would say the converter was flashing around 5000.
Old Nov 4, 2007 | 08:25 AM
matt94z's Avatar
Nice times man!!!
