What are your car plans?
Old Nov 7, 2007 | 01:45 AM
Rowdy94's Avatar
My goal is to make this thing open track worthy by next summer. That means LS1 or C5 brakes, maybe Konis and springs, and I'll possibly sell my wheel/tire setup for some 11" wide ZR1s and sticky rubber. Plus 3.73 Gears.
Old Nov 7, 2007 | 02:37 AM
josh3111's Avatar
8 turbos and 16 radiators
Old Nov 7, 2007 | 05:11 AM
skinnies's Avatar
megasquirt(picking up Saturday)
96lb injectors
Seperate fuel system for race gas
anti roll bar
tubular k member
3 1/2" downpipe
built th400 with a better suited stall
Hyrbird 8.8 with 3.27's
295/50/16 mt dr
slam the car to the ground
Shooting for deep deep 10's on stock heads/cam, on the stock chrome wheels, and with the car still being quiet...ok I lied..I'd really like a 9, but I think it will take more tire to do so.
Old Nov 7, 2007 | 12:19 PM
TAEnvy's Avatar
Who is doing your 8.8? I want one but the guy on here quit making them and I dont have a jig
Old Nov 7, 2007 | 02:23 PM
duff man's Avatar
Mine's supposed to be finished next week.
1. Golen 383/440 hp forged longblock with LE2 heads and ported intake
2. svo 30 lb injectors and walbro pump
3. custom made valve covers
4. built 4l60e
5. Strange Dana60 with 35 spline axles 373 ratio
4. chromoly driveshaft
5. slp double diamond subframe connectors
6. spohn adjustable torque arm
7. LS1 brake upgrade with new slotted rotors and pads
8. Coated 1 3/4 headers (jethot) into 3" true duals (dumped)
9. 2900 stall
10. msd opti
11. 58 mm throttle body
12. tune by pcm4less
13. 28" mickey thompson et streets
Lookin to spray 200 shot before LTX shootout. Hopefully low 11s N/A and into the 10s on spray??
Old Nov 7, 2007 | 02:49 PM
Burning Rubber's Avatar
My plans are a 100 shot and a tune. I am starting on it soon! Hoping for 11.50!
Old Nov 7, 2007 | 03:00 PM
QWIKWS6's Avatar
3.73's
Dynotune
275/60/15 or 325/50/15 MT's
Run 11.5's on 150 shot
stock motor, suspension, and rear end.
3700lbs
Old Nov 7, 2007 | 03:09 PM
I8ASaleen's Avatar
Fully forged 383 with 4-bolt mains and splayed caps.
Dished JE Pistons
LT4 hogged out AFR heads
blower cam and valvetrain
F1A Procharger pushing about 20-25 psi
Any suspension part available
Dana 60 w/3.42's
T-56 built to handle about 1000hp
Pssh that's not even enough...
Old Nov 7, 2007 | 03:30 PM
Akira_X's Avatar
my future modlist in order of what I'm buying or doing
sfc
ground control coil overs
Cai
exhaust
headers
port tb
cam cc503 or custom grind
clutch
Le2 heads
what ya think, suggestions?
Old Nov 7, 2007 | 03:38 PM
skinnies's Avatar
A local shop is building mine.
Old Nov 7, 2007 | 04:12 PM
LT1 POWAH's Avatar
I'm gathering the parts as we speak, but here is what I have planned for it in the spring:
Worked over heads
CC306
1.6 RR along w/ lifters, pushrods, etc
SVO 30lb injectors, racetronix fuelsystem
MSD cap/rotor, Taylor wires, MSD coil, 6AL MSD box
3200-3400 RPM stall from Fuddle
3.73 gears
Eibach pro-kit,
UMI suspension components
New rotors w/ Baer pads up front Hawks out back
Pacesetter coated headers and Y-pipe, TSP Rumbler catback
Trans cooler
ZR1's black in the center w/ a polished lip
6-point cage possibly
There has got to be some parts I am missing but thats the general plan. I plan on racing on a road course more than drag racing.
Old Nov 7, 2007 | 05:07 PM
  #32
Ls1Bait's Avatar
Over winter ...
slicks and skinnies
Wideband o2 sensor
4" glasstek cowl hood
LS1 lid setup
bullet mufflers just for the track
A built transmission (even though mine is good but have heard its better to have a working trans rebuild then a blown one)
And paint my calipers
Then get back to the track and see what happens
Old Nov 7, 2007 | 07:50 PM
  #33
CamaroRacing12's Avatar
Originally Posted by Razor_Blade
My plans are similar to what CamaroRacing12 said. Bolt ons plus massive weight reduction for me.
hey razor what bolt on's do u have done so far? wat is ur current raceweight?
Old Nov 7, 2007 | 07:58 PM
  #34
GreenBlood's Avatar
i am so confused as to what i am am doing with my car...if i keep it...this winter, all the body stuff will be fixed...3200 stall...3.73s...dyno tune...SFCs...etc...who knows...by january, i might be rocking another car depending on my funds...
Old Nov 10, 2007 | 01:59 AM
  #35
bricez28's Avatar
i was thinking flux capacitor and large metal rod to catch lightning when it strikes the clock tower.
and a fwd swap
and type r badges
Old Nov 10, 2007 | 02:58 AM
  #36
hektyk's Avatar
Talking
396 LT1, 550HP N/A with a 200 shot
Old Nov 11, 2007 | 08:49 AM
  #37
z_speedfreak's Avatar
LE2 and a 58mm TB. those were my plans for this year...but **** happens. my shocks are tired so I'l prolly end up getting some strano springs & bilsteins first tho... and some bars
after that, sunnoco hood & new paint..
new rear whenever it decides to take a dump on me.
and a nitrous kit if I can swing it before 100k miles, if not rebuild the bottom end first.
Old Nov 11, 2007 | 10:33 AM
  #38
grn95t/a's Avatar
first, rob bank!
second, don't get caught!!
third, run 9's!!!
note to self! if second doesn't work, try agian in 5-10 years!!
Old Nov 11, 2007 | 10:43 AM
  #39
Fire67's Avatar
After april...
Sell the TA, and build a stock suspension drag radial car.
25.5, 30" tall radials, Fulton big block, gigantic Pro-Charger, etc.
Probably stick with a 4th gen platform, just gonna start with a much cheaper car (think blown up ugly 6 banger 'bird or camaro)
Old Nov 11, 2007 | 12:18 PM
  #40
flyinZ's Avatar
Super Vic conversion
LS1 lid conversion
Sell my Convo Pro's for...something different,heh.
Dyno tune
And a diet as well
