opti help
Old Nov 6, 2007 | 11:36 AM
1lt1wiz's Avatar
Exclamation opti help
drove thee z today came home and the water pump is leaking out of the weep hole is it posable that the opti will go out.
Old Nov 6, 2007 | 11:44 AM
MEAN LT1's Avatar
Usually....if the waterpump starts leaking then the opti is next. Might as well go ahead and replace both while there out. Good luck.
Old Nov 6, 2007 | 11:48 AM
1lt1wiz's Avatar
well it was runing fine just put a new opti on there
Old Nov 6, 2007 | 12:45 PM
onephatZ28's Avatar
New opti or not, if water get in the opti its done. It is alot less money to fix the water pump than the opti.
If you fix the water pump now the opti should be ok
Old Nov 6, 2007 | 02:04 PM
1lt1wiz's Avatar
ok thank u very much i got it to stop leaking and the opti looked dry on the out side i hope it did not hit it
Old Nov 6, 2007 | 02:53 PM
onephatZ28's Avatar
Cool, Good luck with your car
