200 shot?
http://www.cnc-motorsports.com/produ...53&CtgID=22946
and this crank
http://www.cnc-motorsports.com/category.asp?CtgID=8470
you think that will be good for a 200 shot on a splayed 4 bolt block?
2-bolt mains
Block decked w/ pistons .10 or is it .010 in the hole???
.29" GM gasket
Cast Eagle Crank 3.48
Forged JE -5cc Pistons
Forged I-Beam Rods 6" w/ L-19 rod bolts
Im planning on spraying 200 as well on race fuel but not very often. A forged crank and H-Beam setup should be more than enough to handle that amount of nitrous.
CNC Motorsports sells a lot of junk, I bought 1.65 rockers from them to try and nudge a little more out of a combo and when they measured 1.6 CNC could not have cared less, I wouldn't trust them any further than I could thow an engine block.
Cheap rods go out of round after a few torque cycles, best case being another $160 to rebuild them worst case you miss it and they eat a bearing causing who knows how much damage.
Add it all up, bearings, balance etc. The Compstar Speedpack which is Callies "budget" line forged overseas crank and rods machined here by Callies, with Mahle pistons retail about something like $2000-2100 ready to drop in a block, balanced and with bearings. Really a hell of a value.
