egr pipe.
Old Nov 6, 2007 | 11:40 PM
ROUDA's Avatar
Default egr pipe.
ever since I put longtubes on the egr pipe that goes into the header has been leaking Im thinking of just taking it off and pitting block off plates on. But can I just take off the pipe and not the valve itself. Just block the whole on the header and the one on the intake. I see it comes with 3 plates. would doing it this way make it run bad. Theres no cats.
Old Nov 7, 2007 | 06:57 AM
Razor_Blade's Avatar
I've heard that you shouldn't just remove the pipe and leave the valve in place, but I did and I haven't had any ill effects. I just disconnected the vacum so the valve won't open and left the egr solenoid plugged in so I didn't get a code.
Old Nov 7, 2007 | 04:14 PM
ROUDA's Avatar
theres no cats so its not realy doing anything now u no.
