injector not working
Old Nov 8, 2007 | 06:44 PM
LT1 chevelle's Avatar
Default injector not working
I have a 97 model LT 1. I put it in a 71 chevelle. When I got it done I had an injector not working. I put 8 new injectors in it and it was running awesome. Well it started missing again. I also had a header gasket leak. I just put a new plug under the injector that seems not to be working becuase it was fouled out. I started the car and it is still missing. I unplugged that injector and it is not affecting the tune of the motor, but all the others do when unplugged. Suggestions needed. Like I said after I put new injectors in the car it was running sweet, but now it is not.
Old Nov 8, 2007 | 09:00 PM
buffman's Avatar
is it the same cylinder that's giving you problems? Check for shorts, or damage injector connector
