Torque converter HELP
Old Nov 11, 2007 | 03:51 PM
Z93's Avatar
Z93
Default Torque converter HELP
I am thinking about getting a Yank Steath 2800 converter, what do you guy think about this converter for street/strip use?
Old Nov 11, 2007 | 06:09 PM
96capricemgr's Avatar
Yank makes good stuff, might consider going higher on the stall. Inquire about what it will cost in the future to reworking when that POS tranny takes it out. I am not refering to the 700R4 part either.
Old Nov 11, 2007 | 06:28 PM
onephatZ28's Avatar
I have a 2800 right now and I love it, but its not a yank.If I would of went with yank I would of went with a higher stall like a 3200 Yank is real good
GOOD LUCK WITH YOUR CAR
Old Dec 9, 2007 | 09:55 PM
Z-RATED94's Avatar
Since your question mentions street/strip use, I would go with a 3600. You have gears, so it won't take much gas pedal to get the car moving. I went from a 2800 to 3600 and the slight slip upon leaving a stop light is the same between the two. After a day or two, you'll wonder why you didn't do this sooner.
