Center Console Question?
Old Nov 11, 2007 | 11:24 PM
Formula383's Avatar
Default Center Console Question?
Does anyone know if a '98-up center console will fit in a 95? I like the look of the center consoles in the LS1 Formula and Trans Am. Since I'm doing a 6-speed swap, I figured I'd check before I bought one.
I've seen some discussions on the Camaro center consoles but not the Firebirds.
TIA,
Kyle
Old Nov 11, 2007 | 11:30 PM
porksoda's Avatar
They will fit
Old Nov 18, 2007 | 02:28 PM
LT1Formula007's Avatar
I did mine, but I had a problem with the way it fit. There was a tab that caused my console to stick up too high. The console came out of a 98 and I put it in my 94. It only sticks up about a half inch in the back.(near the back seats) But it looks great.
Old Nov 18, 2007 | 05:36 PM
InsaneAuto86's Avatar
The metal hole needs to be made larger to accommodate the new center console. Takes 10 secs with a dremel.
Old Nov 18, 2007 | 10:28 PM
Didn't even pay any attention to that...But thank you for the info.....James
Old Nov 18, 2007 | 10:31 PM
Revelation Z28's Avatar
i cut that plastic tab off and bolted it right on.
Old Nov 18, 2007 | 11:16 PM
Formula383's Avatar
Sweet! Guess I'll get one ordered. The '98 & up ones look soooooo much better. Thanks everyone!
Old Nov 19, 2007 | 07:47 PM
Revelation Z28: Thats what I initially did, but then my console sat ****-eyed so I had to shim it with a few washers to get it to sit straight.... but it looks pretty good in there. and actually has a few cup holders
Old Nov 19, 2007 | 09:36 PM
i had to remove and trim down that bracket that it bolts to in the center. i shortened its height by 1/4".
i need some automotive carpet padding to fill in the gaps that the console doesnt hug enough.
and i need a gap filler for the dash for my gauges.
