1.6rr help
Old Nov 14, 2007 | 07:42 PM
93 black t/a's Avatar
Default 1.6rr help
Hey everyone i'm new here. I just recently bought some Comp Cams 1.6 Pro Magnum Rockers 1318-16. My question is do i need to replace anything else? I'm leaving the factory cam in it. I was told the springs should be fine and to roll the pushrods on a smooth surface to see if they were bent and also examine the ends of the pushrods for flaking or galling. Thanks for your input
Old Nov 14, 2007 | 07:52 PM
94Z28Joe's Avatar
are those the nsa or sa rockers. if you got the nsa one you will need guideplates and hardened pushrods
Old Nov 14, 2007 | 08:06 PM
They're sa. Sorry i didn't state that.
Old Nov 14, 2007 | 08:47 PM
Bones Z28's Avatar
It's a good idea to replace the lifters as well if your putting in new rocker arms.
Old Nov 14, 2007 | 10:19 PM
Boodyrider's Avatar
And personally, I'd do the springs as well. 96 LT4 springs are a cheap (60 or so) reasonable (appropriate pressures and lift capacity for the slight [+about 10%] increase in lift you'll see with the rockers) choice for 1.6s with stock cam. You will also need to verify that the tip of the rocker rolls over the center of the valve tip, or in other words, verify valvetrain geometry. If they do not, you may need a different length pushrod.
Old Nov 14, 2007 | 10:27 PM
kinglt-1's Avatar
You dont need lifters if using the stock cam! Buy the lt-4 springs and you should be good with the sa comp 1.6's
Old Nov 15, 2007 | 12:46 AM
Bones Z28's Avatar
Well let me rephrase that. Your right you don't need lifters on a stock cam, but why not save yourself an extra headache? Especially if the motor has over 100k on it.
Also if you are going to continue to mod you are going to want to replace the lifters any how. In my case over winter when I upgrade to the 1.6's it's foolish not to replace the lifters and springs with them. The lifters are right underneath the rockers, why not? With higher mileage parts you'll install them just to take them out and reinstall them again because something else gave out. Do it right the first time. Now if your motor is relatively new then disregard this.
Old Nov 15, 2007 | 10:37 AM
Rocky70304's Avatar
I think you will be just fine with stock lifters and springs, but would recommend the new pushrods, very cheap insurance...... I bought a set of comp cams pro magnum 1.6:1's and they came with harndened pushrods, check the box, you may have got a set with them also...
Old Nov 15, 2007 | 10:54 AM
blackz6sp's Avatar
No reason to pull the intake for rocker swap.
Old Nov 15, 2007 | 11:16 AM
projekt70chevelle's Avatar
blackz6sp has a very good point, pulling the intake can be a pain. The thing is 93blackt/a, its your call. Anytime i mod my car im always looking for what i should do along with it to make sure i dont break the next thing in line... just looking for that "extra security." If the car is close to or over 100k miles i would deff. suggest swapin the lifters. Is it required for 1.6rr's... NO.... should you do it? probably. The only reason i didnt change the lifters when i put in the 1.6rr's is because i unexpectedly broke a rocker arm and didnt have the lifters for my cam swap yet (which should be goin down in a couple weeks cant wait man). I would suggest doing it just to make sure they dont fail on you in the future. I would also do the springs like boodyrider said, just to livin up that worn valvetrain. Not only that but if you're new to the LT1's it'll help you feel your way around the engine a bit. Like i said its your call bro......
Old Nov 15, 2007 | 11:51 AM
blackz6sp's Avatar
New lifters are for sure extra security, but then again when the old ones go it more incentive for a Cam Swap
Old Nov 15, 2007 | 06:43 PM
sdm1234's Avatar
i have SA 1.6RRs and after 5K mi i checked back on them. i had 2 pushrods broken and i don't beat on it nearly as hard as some people would. everything else was fine, though. i recommend hardened pushrods. if you have a low mileage motor, then your stock springs will be fine.
Old Nov 15, 2007 | 09:39 PM
Wow thanks for the input guys Well the car has 123k on it so i probably need to swap out the lifters I'm guessing you can get a spring tool to the back of the motor with having to drop the motor??
Old Nov 16, 2007 | 06:39 AM
blackz6sp's Avatar
Yeah no need to drop the engine.
Old Nov 16, 2007 | 04:39 PM
Badazz 97 TA's Avatar
Dave, you do realize that you have to pull the whole intake manifold off to get to the lifters? thats more of a headache then anything. disconnecting all the electrical connections, disconnecting fuel lines, vacuum lines etc...
now if he was doing a cam swap then i would agree with you. but for a simple rocker change dont worry about it.
sorry bad picture. the middle is where the lifters are. rockers up top
