30 overbore help!
Old Nov 15, 2007 | 12:36 PM
deuce4935's Avatar
Exclamation 30 overbore help!
Will I need to reprogram my computer if I take my block 30 over?
Old Nov 15, 2007 | 12:44 PM
Rocky70304's Avatar
No, you can run that on a stock program without any harm.
Old Nov 15, 2007 | 01:12 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Yup, no issues but at the same time, why not slug a cam in there, be it is stock.
Old Nov 17, 2007 | 10:57 AM
deuce4935's Avatar
I have the hotcam and I knew it needed to be programmed in, I just wasnt sure about the bore requiring programming also. Thanks guys!
Old Nov 17, 2007 | 01:01 PM
James Montigny's Avatar
The volume difference is small enough that it shouldn't matter.
I asked Ed Wright a similar question about my H/C tune VS swapping
everything over to a 355 and he agreed.
Are you planning on changing your compression ratio? (other than the bore size)
Old Nov 17, 2007 | 01:31 PM
96capricemgr's Avatar
I agree no need to reprogram for just the overbore but I also think it would be a big mistake to not do more too it long as you are that far in and doing more will require reprogramming.
I understand mkoney may be an issue but at the same time it is cheapest to do thing as few times as possible.
