Trickflow Heads
Old Nov 18, 2007 | 08:21 PM
kahunaking's Avatar
Default Trickflow Heads
Has anyone used these heads or have you guys heard anything good about them?
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 18, 2007 | 08:58 PM
joelster's Avatar
I run them. They are decent heads. They are designed for a 383 or boosted 350's. They have bigger chambers which kill the compression a bit when put on a stock 350. I still run them on a stock 350 block, it wasn't my original intent. I am sure that I am down on power compared to if my compression was back to stock. They have a ton of potential if you decide to send them out to get ported by someone like advancedinduction.com . Out of the box they flow around 250ish at their peak, a stock LT1 head will flow about 210ish. There are a lot of aftermarket shops that can port stock heads well beyond what a box-stock trickflow head can do, for around the same amount of money if not less.
Old Nov 18, 2007 | 09:02 PM
96capricemgr's Avatar
For most guys ported stock castings are the right choice, they can support substantial power when worked by the right shop.
