LT1 Patriot spring kit?
Old Nov 19, 2007 | 03:02 PM
jay_rich's Avatar
Default LT1 Patriot spring kit?
I was wondering if anyone here has installed the GOLD Patriot LT1 kit. Do my heads need to be machined for them? I emailed them and they said they SHOULD fit stock heads. I dont wanna buy them and then need to start machining things
Jay
Old Nov 19, 2007 | 03:15 PM
Gunnar@Patriot's Avatar
Jay
They will fit the stock heads just fine.
Old Nov 19, 2007 | 04:10 PM
NightTrain66's Avatar
LS1TECH Sponsor
are these the same "Gold" dbl springs that you sell for the LS1s' but with 11/32 retainers and locks?
How much are they?
Lloyd
Old Nov 19, 2007 | 04:15 PM
speed_demon24's Avatar
The valve stem seals they sent me didn't fit over my valve guides, I don't know if they just sent me the wrong seals or what. The fel-pro seals I picked up to try out wouldn't fit inside the inner spring so I ended up sending the springs back.
Old Nov 20, 2007 | 07:18 AM
LS1TECH Sponsor
how much where they?
has anyone installed and ran a set of these?
I know the LS1 spring set up is a pretty good set up and a good price.
Lloyd
Old Nov 20, 2007 | 09:01 AM
It is the same setup as the LS kit but with all the hardware for the 11/32" valve stems. The LT1 kits are the same price as the LS kit.
