oil filter housing thing
Old Nov 21, 2007 | 11:32 AM
fordeater's Avatar
Default oil filter housing thing
The housing the oil filter goes on that actully bolts to the block is that just a oil filter gasket on it or is that a different type of seal??
Old Nov 21, 2007 | 11:47 AM
bigdan1's Avatar
simple composite gasket on mine : 95
Dan
Old Nov 21, 2007 | 12:30 PM
fordeater's Avatar
so a oil filter gasket works?
Old Nov 21, 2007 | 01:06 PM
Revelation Z28's Avatar
yep! i checked at the dealer and they wanted $14 for that same gasket that you can rip off of an oil filter at autozone. i have an oil cooler from the factory, as you are describing, you do too.
Old Nov 21, 2007 | 01:27 PM
fordeater's Avatar
yea i always thought that was really wierd cause it had coolant running too it so I was wtf is this thing, ill just gank a filter from work. Thanks man
Old Nov 21, 2007 | 01:54 PM
oil it before installing it. i had the same leak youre having(if you have a leak there). make sure its clean on both sides too after you take it off the filter.
Old Nov 21, 2007 | 08:08 PM
fordeater's Avatar
no it didnt leak there but i had to get that thing off to pull the oil pan
