check engine light
Old Nov 23, 2007 | 04:26 PM
ROUDA's Avatar
Default check engine light
I took the egr pipe off but left the valve and hoses conected to it still only thing i did was take the pipe off and block the holes with plates. I did this because I have headers and not cats so it wasnt worth keeping this is a 95 camaro I had the headers on since August and that egr pipe wouldnt seal so i tokok it off now the lite comes on every once in a while comes on and goes out.
Old Nov 23, 2007 | 04:29 PM
fordeater's Avatar
try and get the pcm tuned so they can eliminate those emmision codes
Old Nov 23, 2007 | 04:30 PM
355z28's Avatar
send your computer off and get it tuned, also tell them you need ur cats deleted, and your airpump and egr deleted. That will fix ur light, and run better at that.
Old Nov 23, 2007 | 08:03 PM
ROUDA's Avatar
yea I live like 45minutes from pcmforless Im going to drive up there and take car of it. hoppe thats all it is. it does run like **** sometimes shakes more it seems to.
