58mm TB help!
Old Nov 24, 2007 | 12:08 AM
deuce4935's Avatar
Question 58mm TB help!
Okay, I've got my 58mm Tb and have had the intake bored properly but, the factory air intake piping does not fit over the 58mm Tb. Anyone know where I can get an air intake kit thats fiited for the 58mm TB? I need one that will fit directly over the TB, as I have had the MAF sensor deleted from my computer.
Old Nov 24, 2007 | 12:18 AM
CRAZZ28's Avatar
Just buy a CAI for a 93. they are speed density and do not have a MAF sensor
Old Nov 24, 2007 | 12:30 AM
deuce4935's Avatar
whats a CAI?
Old Nov 24, 2007 | 12:31 AM
Built LT1's Avatar
Originally Posted by deuce4935
Okay, I've got my 58mm Tb and have had the intake bored properly but, the factory air intake piping does not fit over the 58mm Tb. Anyone know where I can get an air intake kit thats fiited for the 58mm TB? I need one that will fit directly over the TB...
Try some lubricant. The outer diameter of the 58 throtle body is "identical" to the factory 48, just the inside is enlarged.
Old Nov 24, 2007 | 12:32 AM
deuce4935's Avatar
I just realized what you're talking about. Too many long hours sniffing exh fumes in the garage. Thanks for the advice.
Old Nov 24, 2007 | 12:44 AM
Built LT1's Avatar
Not a problem. To answer your other question, C.A.I. means Cold Air Induction.
Old Nov 24, 2007 | 07:15 AM
White 96LT1's Avatar
I had the same problem, just put grease on both the elbow and TB and push as hard as you can. just takes a little effort.
