Header gasket
Old Dec 2, 2007 | 12:05 PM
93blacktransam's Avatar
Default Header gasket
ok the car i got had a nasty header leak ..... bought new coppper gaskets and went to put them on and two of the holes are stripped what do i do
Old Dec 2, 2007 | 03:51 PM
any one .........
Old Dec 2, 2007 | 03:57 PM
leonpiper69's Avatar
one word...... heli coil baby!
Old Dec 2, 2007 | 04:37 PM
Schweet97Z's Avatar
lol there is more than one word there my friend
as far as the problem goes....your probably going to have to pull the head and retap the holes...or use a heli coil.
Old Dec 2, 2007 | 05:06 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
you might be able to heli coil it on the block.....no? not sure i never have had to do that.
g'luck with the fix
Old Dec 2, 2007 | 05:24 PM
Ls1Bait's Avatar
If your able to drill out the two bad holes tap them and then heli coil it then you wont have to pull the head. With a right angle drill you may be able to get in there.
