Milled Heads, what pushrods and gaskets?
Old Dec 6, 2007 | 01:10 PM
lov2xlr8's Avatar
Default Milled Heads, what pushrods and gaskets?
I got a set of GTP heads, in addition to being ported and polished, they are milled. Im not sure how much though, I think it's a standard amount among all heads but im not sure. They are LT1 castings though. My question is, what length pushrods will I need and what thinkness head gasket. I see ThunderRacing sells two thicknesses, a .050 and .028. My friend and I are tearing the motor down this weekend, I just want to double check on what I need so there are no problems. Also, I will be running a 150 shot? Should I invest in the ARP head stud kit? Or will the stock be fine, and get the kit when I build my forged motor. Thanks.
Old Dec 6, 2007 | 02:12 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
The gasket thickness will be determined by what compression ratio you are looking for.
I ran the .028-29 with those heads, on a stock shortblock, and my 396...I was also using ARP head bolts.
