Coolant level sensor question
Old Dec 9, 2007 | 10:37 PM
Ironxcross's Avatar
Default Coolant level sensor question
Apparently the coolant level sensor area is leaking and im wondering if there is some way to seal it... short of getting a new sensor? Does the sensor have an o-ring.. maybe one that i could replace with a generic piece. its not a huge leak but its annoying. any ideas?
Old Dec 9, 2007 | 10:45 PM
ls1_doc's Avatar
Thread sealer
Old Dec 10, 2007 | 08:55 AM
artofwarsd's Avatar
yes they do have o rings, two of them. You might want to check the wire clip that holds it in, Its a squarish clip that just holds it against the radiator. Mine came loose and blew out my coolant when I overheated. Dont use thread sealer theyre are NO threads to seal and you could damage the O rings. Also If the sensor is still good I would just try and replace the Orings and or clip. If you have to go new you can find one around 50$ at your local Auto parts store.
Old Dec 10, 2007 | 09:19 AM
355z28's Avatar
My low coolant sensor isnt leaking, but its driving me nuts, my buddys havin the same problem. It always throws the light on the dash, i put a new one on from delco, and he put a new one on that was borg warner worked for a couple days now they're both showing low coolant again wtf?
sorry for jackin..
