Driver side brake light dim!!!!Help
Old Dec 20, 2007 | 10:20 PM
1sicss's Avatar
Default Driver side brake light dim!!!!Help
I have a 1997 CamaroZ28 and the driver side brake light still works but is very dim I'm pretty sure some of ya'll know what I'm talking about I see it mainly on TA's if anyone knows how to fix this please let me know.
Thanks 1sicss
Old Dec 20, 2007 | 10:35 PM
94TRANS's Avatar
my car does the same thing, i dont know either?
Old Dec 20, 2007 | 11:50 PM
Low N Slow's Avatar
The ground connection inside the socket (bulb holder) is probably bad, you can buy new sockets (around $15 each) or if you are patient you can carefully cut the socket open where the ground wire goes in , take the connection apart and clean the corrosion out. The wire and connector will slide back in and lock if you cut it apart correctly. I sealed mine up with some dielecric grease and the have worked great for over 3 years.
Old Dec 20, 2007 | 11:57 PM
Kage's Avatar
Cool
Clean the metal connectors inside the socket, or replace it.
Old Dec 21, 2007 | 12:07 AM
1sicss's Avatar
Default reply to help
Thanks for the help I thought everything was messing up!!!!!!
