trans
Old Dec 29, 2007 | 02:44 AM
1.9tim's Avatar
Default trans
i have a lt1 was thinking about running t56 but dont have the money for one. i have a powerglide and a th400 will bolt up and work what do i have to change.
Old Dec 29, 2007 | 08:18 AM
CRAZZ28's Avatar
You will most likely have to have a driveshaft made. but other than that just make sure the PG has the right bell housing.
Old Dec 29, 2007 | 03:39 PM
Boodyrider's Avatar
Um. If you can't afford a T56, you can't afford to swap from the stock auto trans to either one of those.
I assume you are asking " I have a powerglide and a th400, CAN I use either of these, and what would it take to do the swap?"
