Replacement Bolt
Old Jan 2, 2008 | 05:55 AM
transamws6_97's Avatar
Default Replacement Bolt
While doing my header install this week I stripped the lower bolt removing my steering linkage. Who would carry replacement bolts for this? Autozone? Advanced? or would my best bet be to go to the dealership?
Old Jan 2, 2008 | 07:29 AM
01Z28M6's Avatar
I haven't seen this bolt out of the assembly but it is probably a grade 8.8 or better so you shouldn't just use anything that will work. If it is shouldered or otherwise out of the ordinary you will probably need to go to a dealership or something like gmpartsdirect. If it happens to be a standard bolt then a bonafide hardware store may be able to help you. Just make sure you get the correct grade (shown on the head) as a replacement. Also, make sure it is just the threads on the bolt that have stripped.
Old Jan 2, 2008 | 08:11 AM
gatorhead's Avatar
You could probably scavenge one from a yard as well, but I see no problems with matching the threads and buying one from the hardware store, again grade 8.
Old Jan 2, 2008 | 08:21 AM
no the threads arent stripped its the head of the bolt i stripped when the socket slipped off and rounded the corners. it's just a regular bolt but i didnt know what the correct size and stuff is
Old Jan 2, 2008 | 08:32 AM
gatorhead's Avatar
Take it down to the parts house or hardware store and they can tell ya!
