Best oil for 383?!!
Old Jan 8, 2008 | 02:05 PM
Red1996SS1519's Avatar
Default Best oil for 383?!!
What do you recommend to use on a supercharged 383 engine. What oil?
Old Jan 8, 2008 | 02:07 PM
matt94z's Avatar
I run Castrol 10w40 in mine. It's not supercharged though...
Old Jan 8, 2008 | 03:00 PM
speed_demon24's Avatar
Depends how the motor was built... contact your engine builder.
Old Jan 8, 2008 | 03:13 PM
Shawn @ VA Speed's Avatar
x2 -bearing clearance dictates oil viscosity
Old Jan 8, 2008 | 03:38 PM
borninatransam's Avatar
rotella
Old Jan 8, 2008 | 03:47 PM
black383's Avatar
i only use mobil 1... as for weight.. talk to engine builder
Old Jan 8, 2008 | 05:44 PM
96capricemgr's Avatar
Have you done ANY research, I am not talking reading an advertizement or seeing that everyonre ASSumes that since it qwas put in the Vette that it is best. I mean actually read up on measured results in the LT1?
Guessing not.
Again talk too the engine builder about clearances, if normal clearances we have covered the oils that actually work in LT1s at length and recently.
