Setting Pinion Angle
Old Jan 13, 2008 | 12:29 AM
transamws6_97's Avatar
Default Setting Pinion Angle
Okay so I installed my torque arm tonight and went to set my pinion angle. Used the formula where you take the driveshaft angle minus the pinion angle to get the true pinion angle. My driveshaft read 0 degrees and my torque arm read 2 so 0-2 is -2 which I'm going for. But I measured from the passenger side now if I would have measured from the drivers side it would be 0 - -2 which is 2 degrees so which side do I have to measure from?
Old Jan 13, 2008 | 03:37 AM
Tapout911's Avatar
If you are putting your angle finder on the bottom of the driveshaft and the mounting plate area for the torque on the rear end, side wont matter
