987 Comp spring users, quick question
Old Jan 13, 2008 | 12:24 PM
Bowtie_Aaron's Avatar
Default 987 Comp spring users, quick question
how many of you guys are running the 987 comp springs?
im buying a set of heads (RHS) that have them installed on them.
now my question is, how well will they work with my current cam...
voodoo hydraulic roller
535/550 282/290 (231/239) 110/106
lunati recommends the installed height and pressure to be 1.750 at 100lbs.
are these more or less than what lunati recommends, and will they work with my lift cam?
if not, i might see if i can upgrade to a set of behive springs.
thanks alot.
aaron
Old Jan 13, 2008 | 12:53 PM
96lt1m6's Avatar
i like the 987s they will definately work well with your cam even with 1.6s on them try to not exceed .600° of lift.......some say that the spring combo is too heavy thats why the Pac918 spring is always talked about they are lighter and just drop in w/o machining....
