Limited Street Car w/ LT block
Old Aug 12, 2008 | 09:05 PM
  #61
Paul Bell's Avatar
That's MISTER MODERATOR
WOW, that's a smokin 4th gen!
It's obviously an LT1 block as you've used the opti block off plate. BUT, I've never seen before a SB intake on LT1 heads that uses the water inlet/thermostat housing. What's going on here?? Have you managed to use SB heads on the LT1 block?
Old Aug 13, 2008 | 08:08 AM
  #62
stroked30th's Avatar
These are a very old set of AFR RR heads. They have the standard SB bolt patterns for the intake. They also have the larger Stahl exhaust pattern.
Old Aug 13, 2008 | 08:17 AM
  #63
fast's Avatar
beautiful work
Old Aug 13, 2008 | 03:41 PM
  #64
strokedz383's Avatar
Did you have any problems with the Hedman Hedders (65387) ? I got them on my car with angle plug heads and the tube off of #1 was in the way as far as getting the #3 plug in. They fit the chassis nicely. I don't even have to raise the motor to get them in.
Old Aug 13, 2008 | 05:26 PM
  #65
AChotrod's Avatar
Bad ***!!!!!!!! Top Notch job. Lets see it run!!!!!!!!!
Old Aug 13, 2008 | 05:30 PM
  #66
Yeah, but in the mock-up stage I noticed it and had #1 & 3 primary reworked.
Old Aug 13, 2008 | 08:04 PM
  #67
And they said noone has had a problem with them. I would like to change the primary on #3 to but right know I may have to live with it burning the boot. I'll just have to see what I can get away with. The #1 tube is getting made tommorrow.
Old Aug 13, 2008 | 08:20 PM
  #68
If I was to use the adapter things would have been okay
Old Aug 13, 2008 | 08:29 PM
  #69
seanaugustus's Avatar
First off let me say I need to go change my paints cause thats a Bad *** car. Secondly I like your speedo gauge and I was wondering were you got it? And did you have to fabricate the cluster or did it come with it? Send me a pm with the details pls.
thanks
Old Aug 14, 2008 | 08:35 AM
  #70
thanks
PM'd ya
Old Aug 26, 2008 | 06:36 PM
  #71
OutlawZ's Avatar
Hey Stroked can you give me some info on the radiator that you are using.... and the fan that is attached to it???? Reason I ask is because sometime in the near future to make room and to clean up my engine bay i'm going to do the cut in the front side to side framerail and weld a tube in it's place that you did so i can stand my radiator straight up and down instead of the laid back position that it's in now..... I just was wondering what dimensions of radiator you used and who made it......
Did you get rid of the reverse cooling as well????? Cause I didn't see the return line from the back of the heads to the radiator cap.....
Old Aug 27, 2008 | 08:31 AM
  #72
I had the radiator made. Meziere did the radiator/fan/shroud/ and water pump. I called them told them what kinda room I had and the type of motor/power. They did the rest. EXCELLENT turn around service; they kept in touch with me the entire time they had it.
It's standard LT cooling; there is a line going from rear of heads to Radiator.
-6AN
Old Oct 4, 2008 | 10:52 PM
  #73
LittleRedZ's Avatar
very nice car, congrats on the times! In the process of building a nitrous motor right now. I see you using a plate, whats the second stage and how much are you spraying? powerglide or th400?
Old Oct 5, 2008 | 07:05 PM
  #74
Alot and Alot! Over a 73 jet on both. Sorry but I can't tell all
Th400
Old Oct 6, 2008 | 08:07 AM
  #75
LittleRedZ's Avatar
Th400
where did you get the manual master with the plate that bolts up to the firewall, its all good though keep at it, car looks awsome!
Old Oct 6, 2008 | 09:12 AM
  #76
I got mine from Billingsley, but they are no longer around. You can get the same thing from MADMAN Racing or Burkhart
Old Apr 25, 2012 | 06:10 AM
  #77
yougotboost's Avatar
The bar has been raised...
Old Apr 25, 2012 | 06:22 AM
  #78
bufmatmuslepants's Avatar
yea, 4 years ago...
Old Apr 25, 2012 | 08:41 AM
  #79
Tony Shepherd's Avatar
Can you elaborate? LOL
btw...looking back at this old thread. This is one clean *** build!
Old Apr 25, 2012 | 10:26 AM
  #80
you and stroked30th have damn near identical sig pictures
