Price list to get to 12.4
A guy on here has this setup with an LT1 auto and ran a 12.4 in the 1/4. Any one know the cost of each item for a setup like this?
I would second the "pick a smaller cam" comment from above, the cam I am running is smaller.
The guy turning the wrenches and making the chassis setup hase a huge impact on performance and ET, have to remember there are bolton cars running this number. For the averatge guy to run a number like this in most weather you are looking at a good heads and cam setup and all the supporting mods.
Off the top of my head probably have close to $1000 in exhaust between the headers and all.
$200 in CAI
$2500 or so in the tranny and torque converter
$700 in posi, gears, bearings without labor
$190+ in an electric WP once you consider wiring, this is not a necessary part but is worth some ET, I have stayed mechanical as they fail slowly rather than completely and suddenly, I do see an electric in the future for my car though.
$300 for a new opti but I would instead just spend $150 on a MSD cap and rotor and use the existing base.
$100-400 for a driveshaft depending used or new
No idea on the subframe connectors, I run a full framed car.
A full cam swap will cost over $1000 in most cases if you REALLY add it all up, springs, rockers, pushrods together cost more than a cam, figure what about $220 for beehives and retainers, $260+ for rockers, should do guideplates $50 for the Isky adjustable and $30 for new studs(go 7/16"), good pushrods are usually over $100, actually we haven't even considered the gaskets or labor on things like the rearend which most guys wont do themselves.
Lot of big numbers there, it can be done cheaper I am just giving averages for cost and what it will take to get most people runnning a car this fast.
As I said above you should probably be considering heads as well which is more $$$$$
