help looking for adjustable timing set for lt1
Old Jan 18, 2008 | 08:37 PM
nasty96's Avatar
Default help looking for adjustable timing set for lt1
i have a 96 lt1 that i have eliminated water pump and opti. and i need to degree my new cam where can i find an adjustable timing set ?? i have heard that you can run an 85 and up timing set which is alot cheaper and can find everywhere but everywhere i call can't tell me wether it will work bolt pattern may be different.. anyone know or is anyone running that set up
Old Jan 20, 2008 | 05:20 PM
nasty96's Avatar
anyone know or run into the same problem.??
Old Jan 20, 2008 | 05:34 PM
Speed Density's Avatar
hashtagBMW
Lots of us are running Cloyse double rollers.
Tony.
Old Jan 20, 2008 | 07:11 PM
zigroid's Avatar
I have a cloyes hex-a-just timing set for sale. you have to grind on the block and timing cover a little bit to get it to work.
Old Jan 20, 2008 | 07:57 PM
nasty96's Avatar
thanks guys..can i get that part number TONY.. and are you still running the stock size lt1 cam with the step nose
