What could be wrong? dyno issues
The car is a 93 Trans Am
It has: 355 rebuild
Comp 503 cam
Mild ported heads
Msd opti
2600 stall
373 gears
and here is the dyno graph. the air/fuel stayed around 12.4 until it started to fall of at 5800 rpms
Those numbers are pretty low especially given the fact it was a dynojet and not a mustang dyno.
About the rev limiter, thats what i thought it may have been but since alvin was dyno tuning at that time we would have been able to control that, we also bypassed the msd box thinking that may have been the problem but that didnt fix it either.
could it be that i just have week lifters or would that not cause this problem?
Also, I'm sure Alvin would've changed it, but the stock Rev Limiter is set @ around 5850rpm.
It definately wasn't a rev limitor. The PCM rev limitor was 6500 and the MSD box didn't have a chip in it so infinite. He said he used the lifters that cam in the rebuild kit (cheap) I'll put money on htats where the problem is.
It didn't pull a vaccum on the intake at WOT so the intake was nice and healthy.. ON top of that he had beautiful exhaust so theres not much else it could be. The peak appeared also to be in the right area so I would bet that the cam timing is also right.
Folks, when you buy used heads, spend the bucks to get them flowed and freshened at a competent speed shop! Yup, it'll cost you, but valves that don't seal well don't make power!
I'll proceed to
