lots of questions all help greatly aprieciated
Old Jan 24, 2008 | 12:45 AM
transamsam98's Avatar
Cool lots of questions all help greatly aprieciated
what all can be removed from a car that is a street car mostly and retain drivability and most of the safty? also what parts are worthwhile swapping out for weight savings and prices are great to if yall can lend a hand. in the ways of removing rerouting or swapping parts if you could supply a giude or pictures of the procces that would be awsome to. thanks in advance guys.
Old Jan 24, 2008 | 01:15 AM
LT1Formula007's Avatar
A/c Delete is the biggest mod to reduce weight. Also pulling out the HVAC Box and cutting out the a/c portion of it helps eliminate weight.
The back seats if you don't need them.
The front sway bar.
Anything inside the car you don't need.
The airbag in the Passenger side of the dash (about 20 lbs)
And also the spare tire and Jack
If you have time or want to, you can always pull out the factory carpet and replace it with lightweight carpet. Just a few things to help reduce the weight of a street car. Some of the over looked areas are under the hood items such as ABS Unit, And other things not used regularly.
Good Luck
James
Old Jan 24, 2008 | 02:20 AM
onephatZ28's Avatar
Check this out
https://ls1tech.com/forums/drag-racing-tech/846228-weight-reduction-list-fully-updated.html
Old Jan 24, 2008 | 06:05 PM
very Helpful Thread Right There
