Question on OEM fuel line material
How do I go about reattaching these lines back to the fuel rails? It appears that the original lines were just shoved on - no clamps or anything. Do you have to heat the material before you shove it on to get it to expand? Or do you heat it afterward to shrink it tightly onto the barbed lines on the fuel rail? With the higher fuel pressures necessary for the FI, I want to be sure it's well attached, but I think a couple of clamps will look pretty cheezy.
What would be the correct way to reattach these lines so the look as "stock" as possible?
