AFR heads on LT1?
https://ls1tech.com/threads/showflat...31&fpart=1
Now, if I could get my hands on a reasonably priced pair of LT4 pieces I would go with them in a heartbeat.
The AFR heads I purchased direct from AFR and it was at least 3 months to get them. Then when I recieved them the CNC porting from AFR was crude! I found different area's in the exhaust port and intake port where the cutter missed. I called AFR and they said that happens. I figured that was pretty poor answere and after spending $2400.00 I really was expecting a great set of heads. The other thing I found out was the flow numbers they claim and I verified if there heads would be different once I recieved them and AFR said NO the flow numbers will be what is advertised. That's the farthest from the truth and I found out when I had a new motor built using these heads because the flow numbers where off by 15 cfm plus.
Like I said if I had to do over I would have purchased them from a reliable engine builder with his port work.
LT1 head flow numbers
good luck with your project
For my turbo motor i choose brodix heads and had them ported by a very reputable shop and love the looks. can't wait to go vroom vroom though
Steven
